StrokerMax
- 161
- 11
- Mar 27, 2014
Colorado Spring,
Colorado
I'm hoping someone can point me in the right direction for my tuning problem.
I have FIC 2150's, a Walboro 450, and all aftermarket fuel lines and rail running 100% E85. I'm having a problem tuning my AFR with ECMlink. At 18-20PSI boost my AFR might start at 12 and then creep up to 14 through the gear at WOT. My AFR estimate in ECMlink isn't matching the reading with my Wideband... Its way off. For example: my open loop max octane table will be set at 9.5 and the wideband shows my AFR is 12 and creeping to 14. I just want it to hold 12.
I'm still running the stock front O2 and my wideband is tapped in the O2 housing as well. I'm assuming the problem has more to do with calibrating my wideband with ECMlink than running out of fuel pump. Maybe I'm wrong.
I have an Autometer C2 digital Wideband (7178). I'm wishing I went with the Innovative or AEM as it seems like they are easier to pair with ECMlink. I'm not looking to eliminate my stock O2 or anything. Just looking for the easiest method to ensure accurate AFR tuning. I'm not sure what I'm doing wrong. Any advice is greatly appreciated.
Thank you
Thank you
