DSMRevolution
- 1,629
- 11
- Dec 6, 2002
Sioux Falls,
South Dakota
I have a leaking transmission that I can't find where the leak is coming from. It gets transmission fluid all over the chassis brace that runs front to back on the passenger side. It drips off that too. There is also a small amount on the transfer case (more towards the fill plug) and some right on the underside of the transmission. A small amount drips out of the clutch slave cylinder rubber piece that goes into the transmission but I don't think that is where the leak is coming from (correct me if i am wrong). The only place it drips down though is off the brace. I think it is the transmission leaking at least. It doesn't seem like it would be the TC because that is always full and the transmission gets low. I hate to see some good GM Syncromesh goto waste! PLEASE HELP!!!
Thanks in advance
Thanks in advance
