AlphaAssault
- 480
- 1
- Sep 5, 2007
Tyler,
Texas
ive got an odd leak that just developed this past week. a large oily puddle will form under the car at random. some days it wont leak, no matter how much i drive it. other days, it will leak a puddle 6 inches in diameter. its been hell tracking this down, because up until today, every time i try to find the leak, IT ISNT LEAKING!
anyway, i finally caught it in the act today, and the fluid appears to be dripping from the front of the transfer case, just barely missing the passenger-side cross member. ive uploaded a picture of what ive found: the yellow dots are beads of fluid. this is where the fluid actually drips down onto the ground from. the yellow line indicates more fluid, but no dripping. the blue dot is an oil drip originating at the oil pan that i dont *think* has any relevance, but i put it in there just in case.
im running syncromesh in the trans right now, so trying to tell the syncromesh from regular motor oil is a pain in the ass. however, im fairly confident that this leak is trans fluid and not motor oil. what i would like to know is what seals on the trans would produce a leak like this? as far as i can tell, it could be the output shaft seal to the xfer case, an axle seal, or the input shaft seal inside the trans. any help is welcome, especially from anyone who has experienced this issue.
EDIT: sorry, i meant to include this: the transfer case is NOT leaking. it was recently inspected.
