1G Transmission Failure Question
Posted by a91eagletalon, Mar 12, 2018
Please Support Boostin Performance
  1. a91eagletalon
    a91eagletalon Supporting Member
    210
    13
    Joined Aug 24, 2005
    Norfolk, Nebraska
    OK so this is a 100% new build with a 23 Spline 1g trans I purchased from a guy that had it built already.
    Gear sets are faceplated from liberty Gears cryotreated and shot peened.The gears are evo3 1st with new evo3 input shaft, stock dsm (but new) 2nd, evo3 3rd and 4th.syncro 5th and reverse
    4 spider center diff from Jacks, new seals, bearings, steel forks, faceplated 1-4,
    My question is I had instant failure of fourth gear. the second I put it in gear for the very first time wile moving it exploded. Was not under a pull just normal driving testing it out. this build had only like 3 miles on it before it broke.
    My question is what do you think caused it I will attach pics of the gear sets new well what pics I have and also I will attach pics of the broken trans.
    Let me know what you guys think
    New pics
    received_1712378465447754.jpeg received_1712378458781088.jpeg received_1712392158779718.jpeg Bad Pics
    Log in/Register to remove ads
    My DSM:
    1990 Eagle Talon TSi AWD
    Street Build
      manual
    Loading...
  2. pauleyman
    pauleyman DSM Wiseman
    4,614
    755
    Joined Nov 19, 2011
    oklahoma city, Oklahoma
    Ouch. Maybe a foreign object left behind.
    My DSM:
    1997 Eagle Talon TSi AWD
    Street Build
    T25   manual
    Loading...
  3. bastarddsm
    bastarddsm Supporting Vendor
    4,146
    752
    Joined Aug 26, 2003
    Mendota, Illinois
    That's a typical failure from making lots of power and trying to powershift into 4th.
    4 possible situations.
    1. Sometimes it just sucks to suck.
    2. You are not telling the whole story and tried to really jam gears while making lots of power
    3. Foreign object damage
    4. Trans wasn't really all new, and 4th/intermediate shaft was allready used up and about to fail.
    I'd be mad as hell if that was my trans I paid good money for. Not because of the failure, because of the pictures. It looks rusty as hell, and dirty prior to assembly. 2nd and the intermediate shaft look used. Perhaps the intermediate shaft had some cracks in 4th gear, and was ready to fail when the trans was assembled.
    Good news is it should be like a $500 fix. New shaft, 4th gear, and have libery re-faceplate it.
    My DSM:
    1991 Eagle Talon N/T
    Showcar Build
    9.805 @ 144.00 MPH
    Loading...
  4. pauleyman
    4,614
    755
    Joined Nov 19, 2011
    I wouldve used a new intermediate shaft. You can see the small chips in the gears.
    My DSM:
    Street Build
    T25   manual
    Loading...
    o0GuitarKid0o likes this.
  5. a91eagletalon
    210
    13
    Joined Aug 24, 2005
    Norfolk, Nebraska
    1.Yes it dose Suck to Suck
    2. You are getting the whole story if i broke it under a hard pull i would know why it broke.
    3. Possible
    4. I cant confirm it was new everything else is new.
    And yes I am mad as hell. You bring up some good points I should have inspected the pics a lot better.
    I just wish there was a clear cut reason why it broke. It is what it is ill get new parts coming and get it back on the road again.
    And just to confirm the intermediate shaft is from the dsm transmission right 92-99
    My DSM:
    Street Build
      manual
    Loading...
  6. ist dwa
    ist dwa Proven Member
    150
    21
    Joined Nov 5, 2009
    Centerville, Ohio
    real power = need of dogbox. gimmics are gimmics
  7. bastarddsm
    4,146
    752
    Joined Aug 26, 2003
    Mendota, Illinois
    Yes that looks like a 92-99 intermediate shaft. I would also just get normal dsm gears and not the Evo gears.
    My DSM:
    Showcar Build
    9.805 @ 144.00 MPH
    Loading...
  8. bastarddsm
    4,146
    752
    Joined Aug 26, 2003
    Mendota, Illinois
    Thanks for your insightful and helpful input.
    My DSM:
    Showcar Build
    9.805 @ 144.00 MPH
    Loading...
  9. a91eagletalon
    210
    13
    Joined Aug 24, 2005
    Norfolk, Nebraska
    Your talking just 4th gear
    My DSM:
    Street Build
      manual
    Loading...
  10. bastarddsm
    4,146
    752
    Joined Aug 26, 2003
    Mendota, Illinois
    Probably 3 and 4.
    My DSM:
    Showcar Build
    9.805 @ 144.00 MPH
    Loading...
  11. a91eagletalon
    210
    13
    Joined Aug 24, 2005
    Norfolk, Nebraska
    Is the EVO 3 4th gear even compatible to mesh with the gear on the dsm shaft.
    My DSM:
    Street Build
      manual
    Loading...
  12. twicks69
    twicks69 DSM Wiseman
    3,135
    523
    Joined Mar 12, 2004
    Milwaukee, Wisconsin
    Did the 3rd/4th shift fork get properly clearanced so it wouldn't hit the face plates? Using an evo 3 fork needs modification. As well, if have to look at more pictures of the stuff on a PC to see closer than looking at this on my phone. The gearset spread, could be a shimming issue , could be a contact issue at the shift fork, it could be a beam weld for a face plate jamming on the hub causing a lockup problem. Either way, it could have been a list of several failures including either an intermediate shaft flaw or gear flaw.
    My DSM:
    1999 Mitsubishi Eclipse GSX
    Drag Race Build
    9.499 @ 155.00 MPH
    Loading...
  13. a91eagletalon
    210
    13
    Joined Aug 24, 2005
    Norfolk, Nebraska
    That I am not sure of I can look and see if you tell me what to look for and i can take a couple more pics with the case off.
    My DSM:
    Street Build
      manual
    Loading...
  14. twicks69
    3,135
    523
    Joined Mar 12, 2004
    Take the case off and pull the clusters so we can take a look at the fork and the gearset.
    My DSM:
    Drag Race Build
    9.499 @ 155.00 MPH
    Loading...
  15. a91eagletalon
    210
    13
    Joined Aug 24, 2005
    Norfolk, Nebraska
    here is it taken apart. Now when you say clearance do you mean between the slider and the fork. And or the dog teeth and fork
    IMG_20180313_182337011.jpg IMG_20180313_182346722.jpg IMG_20180313_183411636.jpg IMG_20180313_183331798.jpg
    My DSM:
    Street Build
      manual
    Loading...
  16. twicks69
    3,135
    523
    Joined Mar 12, 2004
    I mean specifically the dog rings on the gears contacting the shift fork, just like the machined down area on the shift fork. Now, is that fork machined down from contact or is it actually ground down to clear before this incident.
    Can you rotate 4th gear on the input shaft smoothly by hand? 3rd too?
    My DSM:
    Drag Race Build
    9.499 @ 155.00 MPH
    Loading...
  17. a91eagletalon
    210
    13
    Joined Aug 24, 2005
    Norfolk, Nebraska
    Yes they rotate smooth everything clears I don't see any indication where the dog ring contacted the fork
    My DSM:
    Street Build
      manual
    Loading...
  18. twicks69
    3,135
    523
    Joined Mar 12, 2004
    Well I see marks on the fork , take a closer look.
    My DSM:
    Drag Race Build
    9.499 @ 155.00 MPH
    Loading...
  19. bastarddsm
    4,146
    752
    Joined Aug 26, 2003
    Mendota, Illinois
    I can't tell, but does your intermediate shaft have chips in the teeth on 3rd gear?
    My DSM:
    Showcar Build
    9.805 @ 144.00 MPH
    Loading...
  20. a91eagletalon
    210
    13
    Joined Aug 24, 2005
    Norfolk, Nebraska
    Yea it dose now it looks like damage from other broken teeth
    My DSM:
    Street Build
      manual
    Loading...
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrications OHM Racing Race Components Inc RockAuto Spultronix Performance STM Tuned Strictly Import Motorsports Tire Rack VR Speed Factory White Shed Speed
