Please Support STM Tuned
transfer case
VaB90gsx
34
Oct 15, 2003
Virginia Beach, Virginia
i unbolted the 4 bolts to the transfercase that hold it to the tranny.. i wanted to unbolt the transfer case and the driveshaft together and pull them both out.. the exhaust is completely unbolted and out of the way... question is.. can i do this myself without damaging teh driveshaft? and are the 4 bolts in the haynes manual the only bolts necessary to take the transfer case off.. if so i just unbolt the two clamps that hold the driveshaft to the chassis and pull towards the driver side of the car. any input is appreciated.
-doug
TIe up the driveshaft with wire and pry off the transfer case and put something for it to fall on. It will slide right off the driveshaft. I think there are 5 bolts to get off though not 4. One is hidden up top and a bi*** to get out. I used a 3ft extension and went though where the tire is to get to it.
Edit - Sorry Didnt realize you wanted to take out both together.
