2G Torque solution mounts review
I got done installing my timing side and rear engine mount from torque solution and I thought I would write a review since no one has. I thought these would be better then the avids but they still needed to be modified let me explain.
the fitment in the mounts itself is fine they go in as they are ment to, the timing side is a bit big on the bush so it wont sit straight so it is always off center so a sander would help remove some of this but i chose to do the hard way and make it fit without sanding and that took about 1 hour and a hammer LOL
the issue is the insert sleeves are either wayyyyy to long or the hole size is alot bigger so a 10mm bolt had a 15mm hole??? this may make installing easier but not for making it stop moving so I decided to make my own sleeves and give it a nice 1mm clearance or .5mm both sides and its very snug now, if i did not rdo these the sleeves they send you are too long aswell so would never go in. oh and they mixed sleeve material aswell! one was stainless and the other was steel? who does that!!!
I have messaged them and ask if they just copied avid's mounts as they look exactly the same and fitment and what the issues were and they just ignored me! i messaged them start of november! still no reply
so im not saying dont buy them but if you do be aware that the sleeves will need to be made again or modify the lengh if you want to keep the sized holes they make them
I do not have any pictures with the sleeves before i made new ones and my phones memory card wiped them all out so im sorry for that.
overall they are good mounts and happy with them but the sleeves were a pain you could just do without!
Bobby
