Toms River - NJ
End of march i should be up and running. Just got my downpipe back from the ceramic coater. Gotta finish up the back part, relocate my altenator, swap in the new injectors, and go do some highway blast to dial her in. Woops forgot about swapping the trans, setting up the coilovers....DAMN IT!
Thats crazy
I might be up and running by then...
I've been changing my mind last minute and getting more work done before assembling it
haha
My front passenger axle is giving me trouble right now. It was seized in the hub so I had to order another knuckle from dsmgraveyard. And of course, nothing wants to go back on correctly. Looks like tonight is going to be a late night.
hey man if you ever want help hit me up im always down for working on cars
just so you know, i rent my garage out for 35 an hour. i have a lift and air compressor. and most importantly, HEAT... LOL theres only two conditions. you car must be done same night. and you cant not use my tools. i am very stricked about that.
on the lighter note... my car is up and running, only thing left is clutch and flywheel. car still runs like shit... and still cant figure out dsm link for the life of me.. i am a retard or something... i dont know. LOL hit me up, im at work and i highly doubht anyone is getting there cars worked on in this snow.
I finally got my car done. That was such a pain. However, even though I didn't touch anything on the turbo, everytime I go into boost now my car whines like it has a supercharger. You can still here the turbo spool up, which leads me to believe that it isn't a bad turbo. Plus, the turbo is almost brand new. It's weird.
That my friend sounds like a big ass boost leak... check your intercooler pipes. oh and i posted a few pics of my motor with some of the stuff on it... check it out and let me know what you think
Yea but the vacuum is right at 18 at idle. And it boosts 25psi NO PROBLEM. Oh and I looked at the pics. I like the external gate!
Idk what turbo you have but I have heard 14b/16g's whine before they go bad.
I call it the death whine, have seen it time and time again.
Does it go away as you beat on it alittle? Ill put money on a big crack in the turbine housing by the wastegate flapper door. Typical sound, and its alittle bit of air weeping through the crack. Sometimes it will go away as the metal gets hotter and expands.
It is an FP 18g that is only a few months old.
It doesn't go away. Then again I have only driven the car twice for a short didtance. I will be driving it to work today which will be 2 hours round trip. We will see if anything changes.
edit: just a side note, there is no unusuall shaft play.
Start off by boostleak testing it..
Are you feeding from the head or OFH? Filtered?
If it dosent smoke, and has no unusual shaftplay its definatly a crack in the turbine housing by the flapper door, or a boost leak. Im leaning more toward changing the turbine housing.
I don't see why a FP 18g would have a cracked turbine housing
Thats a 14b thing of the past.
Anythings possible I guess tho...
I will check that.
If it is a cracked housing, it better be covered under warranty.
I had a 7cm housing do it, I havent played with those housings for awhile, but yeah anything possible, including a blown o2 housing gasket :thumb:
