faces240
- 167
- 0
- Sep 25, 2003
Toms River,
New Jersey
ok so i fixed my fan and my temp guage also figured out another problem but now a new one has come up i took it to the street to see how it drove and i didnt get past 5 mph or 25 feet before turning around and geting it in my garage..
the whole car was shaking and loud clicking like a cv axle was bad or drive shaft is loose.
i shouldnt have these problems cause ammco put in the trans and cv axles and drive shaft also transfer case idk what to do anymore im actully going to have dogbox look at it and if it was a install error im going to sue the pants off ammco i still gota read this code thats being thrown..
are you still having reverse problems? did you find your reverse switch and take it out yet? its on top of your tranny, under where the airbox should be, its gonna be a big bolt with a black 2 wire plug on it. should be right by the ground strap going from your frame to your trans.
. what can ya do right. thank you for the buisness. and to phil, you dont want to use a distribution block on your ground cable, you want them both to be as short as possible.
