1. Join the Community!
tires wearing inner edge
Posted by importboost, Aug 7, 2006
Please Support ExtremePSI
Please Support Southbay Fuel Injectors
  1. importboost
    importboost Proven Member
    236
    6
    Joined Jan 19, 2005
    Holly Springs, North Carolina
    After searching about this I found a million threads bout peoples tires wearing but it was always a lowering issue. My cars suspension is stock. My tires have been on there since before I owned the car, which is over 2 yrs. But a few days ago I noticed that the inside edge of my front two tires were worn down smooth. Is this a common dsm thing? I know the Lexus my friend has wears through the inside of tires like nothin, but his alignment is fine. Its just how it is with Lexus I guess. I called Mitsu today about that mass balljoint recall and they said mine had been done in April of 04. So I really doubt they are out again, not saying it isnt possible. Is there a way to adjust camber on our cars? Im planning on bringing it to a shop to have the alignment checked. Gotta get a new tire on it first(one wore to the belts on the inside). Any help much appreciated.
  2. jtmcinder
    jtmcinder DSM Wiseman
    5,403
    79
    Joined Nov 4, 2003
    Iowa City, Iowa
    What is your current toe?
    Have you lifted each front and yanked on it?
    - Jtoby
  3. importboost
    236
    6
    Joined Jan 19, 2005
    I havent checked anything yet. Broke my jack not to long ago and havent replaced it yet. I thought toe didnt effect that part of the tire?
  4. blk 2gnt
    blk 2gnt Proven Member
    94
    Joined Mar 31, 2003
    Long Valley, New Jersey
    Toe was the first thing that came into my head.
  5. importboost
    236
    6
    Joined Jan 19, 2005
  6. blk 2gnt
    94
    Joined Mar 31, 2003
    I can only tell you from my own experience. When I noticed the insides of my tires wearing I had my alignment done. My camber was not too far out of spec but my toe was out an unbelievable amount. If I can dig up my print-out, I'll post up what my numbers were.
    *edit* I did a little investigating just to make sure that I was remembering my suspension stuff correctly. Check out this link:
    http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=4
    The section on toe starts about 3/4 of the way down the page
  7. Defiant
    Defiant DSM Wiseman
    34,773
    159
    Joined Jan 13, 2003
    glorious Galt, California
    Camber will affect where the tire's contact patch wears, but toe will erase the tread faster than a dyslexic's Eberhard-Faber.
    3K  0
    1995 Eagle Talon TSi AWD
    manual · 2G DSM
    Loading...
  8. importboost
    236
    6
    Joined Jan 19, 2005
    Lol well put, would inner tire rods effect the toe or just the outer?
  9. jtmcinder
    5,403
    79
    Joined Nov 4, 2003
    Iowa City, Iowa
    Yes, as would bad bushings or ball-joints. That's why question #1 concerned toe and question #2 was whether anything is loose.
    - Jtoby
  10. importboost
    236
    6
    Joined Jan 19, 2005
    I got ya, well last time I had it on the rack the inners were loose. Nothin else. But since I havent checked the toe yet I couldnt tell you what it is.
  11. jtmcinder
    5,403
    79
    Joined Nov 4, 2003
    Iowa City, Iowa
    Are the tires really worn down smooth or are they either scalloped or feathered? This is something you can check now and would provide relevant information.
    - Jtoby
  12. importboost
    236
    6
    Joined Jan 19, 2005
    Yeah, I didnt know if that would help. They are smooooth smooooth, inner edge is GONE LOL.
  13. jtmcinder
    5,403
    79
    Joined Nov 4, 2003
    Iowa City, Iowa
    Interesting. By eyeball, what do you think the camber is? What is your typical pressure?
    - Jtoby
  14. importboost
    236
    6
    Joined Jan 19, 2005
    Camber looks fine, from the naked eye my tires are straight. Tire pressure is regularly checked and set at around 32.
  15. jtmcinder
    5,403
    79
    Joined Nov 4, 2003
    Iowa City, Iowa
    Ah. 32 is a tad low for a car that weighs around 900# per corner up front (unless you are drag racing). But that still doesn't explain it. Totally smooth inside edges are usually caused by camber plus some toe-out. Mere low pressure would wear the outer edge, too. Lots of toe-out would feather the inside edge. Loose suspension parts would cause scalloping.
    I'm worthless.
    - Jtoby
  16. importboost
    236
    6
    Joined Jan 19, 2005
    So your thinkin its my camber? What are my options if it is? I know we dont have adjustment bolts, but I've heard of shimming them to correct the problem. What can I do if it is a camber issue?
    It doesnt feel like my ball joints are going bad when I drive it.
  17. Defiant
    Defiant DSM Wiseman
    34,773
    159
    Joined Jan 13, 2003
    Alright, stop. Replace those and have it aligned, step one.
    3K  0
    manual · 2G DSM
    Loading...
Share This Page
Boosted Fabrication ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing Raven Fabrication RixRacing RockAuto RTM Racing SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory
