justinh722
- 130
- 1
- May 3, 2010
Hampton,
Iowa
I just had a tensioner go bad on me so I just got another one tonight. I'm installing it and I remember I'm supposed to tighten the tensioner pulley until the grenade pin is loose enough to slide in and out with ease am I correct? I know the correct way to do it is put 24 in lbs of torque on it but I don't have a small torque wrench. Also, the crank trigger plate appears to be loose and the belt sits on the crank sprocket closer to the inside. It seems like the crank pulley is loose. Is there a way to tighten the pulley to spec without the holding tool? I snapped some pics to see the timing marks and the crank pulley.
