2G Timing belt woes (Exhaust cam off slight, crank off, and tensioner troubles)
squid267
158
3
Jan 14, 2012
Worcester, Massachusetts
Doing my first timing belt job, aswell as 6 bolt swap. I have numerous VFAQ, and other tutorials and I just want to confirm a few things
1) My exhaust camshaft is off by the slightest bit. It was lined up as seen here
Rotate crank 6 times and this is how it looks
Is this the exhaust natural tendency that the faqs and tutorials were talking about or something else?
2) My crank after 6 rotations.
is off or am i being too ocd
3) The hydraulic tensioner after 15 mins does not raise that much. and i can still push a grenade pin thru. some faqs say its okay, some dont. whats the correct answer here :confused:
Thanks! hope to get back on the road asap
In the first pic it seems as of both need to be turned in 1 more tooth! It does look slightly Off but its not a whole tooth out from what I can see
I concur, both cams gears appear off one tooth. exhaust needs to go clockwise one tooth and intake counterclockwise one tooth.
BTW you'll have a much easier time with the belt covers if you remove the studs on the motor mount.
that plastic guide is upside down face flipped. basically the cam marks will line perfectly if you have the plastic guide installed right, which in the first pic, it is not.
It's the Jay Racing tool, website says face arrow up
Jay Racing Timing Belt Tool, Fix Cam Gear Position [TBT3] - $25.00 : Jay Racing
Edit: redid it few more times. everything lined up nice.
this was cams before
but then rotate crank 6 times...
exhaust cam is off. is that natural tendency bs?
The plastic piece is not wrong in the first pic, teh cams are just not in the right place. The orientation of the tool was correct. As for this latest pic rotate six times, line up the crank dead nuts (hint: don't look at the came at all) and then look at them. They should be dead nuts also. My guess in that last pic if you're very slightly off on the crank mark so it appears it's off when it really isn't. Basically, I think you have it right.
removal of the leaves and oily residue would be a good idea. i learned the hard way
So non of your pics show the cams in the right position. Imagine a straight line or better yet get a ruler and use it as your guide. The cam marks should go straight across and pretty much should go straight across where the valve cover meets the head if your looking straight on ( hope that makes sense). You need to redo your timing till its dead nuts on everytime you rotate and check. Get the cams perfect with the plastic cam tool then wrap the timing belt around over the idler then oil pump them crank pulley then tensioner pulley. Do you have the other tools for the timing kit? What are you using to tension the tensioner. If this isn't done right you will mess up your engine no way around that bro!!
Not necessarily. Mine I redid three times, started the engine, had idle surge, then did it again. I couldn't get all four timing marks to lay out straight. At all. It just seems like its a half-tooth off. But technically it can't be. You want to rotate the exhaust can to where its already starting to push two valves, then rotate the intake can back so that the marks align, then use the belt with two clips to hold the tension while you route the belt as described above.
You only need to worry about the two inside marks lining up perfectly straight. Which in the o.p's situation hasn't happen yet from what I see. But in all honestly all 4 should make a straight line like in this pic.
Yea that's what kept making me reset mine. I could get the two inside marks to line up, but then all four wouldn't be in a straight line. But you're right. By the the first set of pics, ex can was retarded one tooth. Couldn't see the second set.
All set guys. Here some tips for other people in this situation
1) Even with plastic tool you may need to rotate exhaust, and possibly intake inward a little bit (Depends on how exact your tool is)
2) Ziptie both exhaust AND intake cams, so the slack is between exhuast cam and tensioner pulley
3) if there slack between oil sprocket and crank you will be out of phase when you tension the pulley.
If you're having issues just come back it later, you wont get perfect first try. Took me 3 days!
Good Luck!
