Please Support Morrison Fabrications
Resolved 1G Timing Belt Tensioner question
68442
639
5
Oct 14, 2007
Des Moines, Iowa
I read how to slowly compress, and they should come out slowly. Both that I have cannot be pushed in using all my weight but come out immediately when the vise is released. Junk?
Either action, compressing or releasing the tensioner, are supposed to be done in a slow and controlled fashion. That is, any force applied to the rod is meant to be relieved slowly, not just sprung loose to where the tensioner can immediately extend.
Are these used tensioners?
Yes used, was trying to determine if they are bad or not, a topic about this comes up when you search.
A Wiseman said that a good tensioner will extend slowly with pressure released from being compressed. I kinda doubted that. My assumption is if they are strong enough that you have to use a vise to compress and aren't leaking they are probably good.
Since I'm sick of working on them I'll be buying a new one anyway LOL.
