Timing belt help.......
Chuckt
681
Oct 17, 2002
Not sure if its the timing belt or what, but the belt that controls everything in the car just blew again. I was driving and i revved and noticed my power steering went out. Once i stopped i realized the belt blew out on one side and had flipped itself over. Less then a month ago, the same thing happened and i got the tensioner belt replaced and now im having the same problem again. Any help or info on why this is happening?
If your timing belt did that you'd be looking for a few new valves. Sounds more like your accessory belt fliped. First check to make sure that you crankshaft pulley hasn't seperated from the hub (common problem). When they do they can start wobbling and throw belts.
Steve
yea, it was my powerteering belt/ac belt that went out. I dont know much about working on my car, so i took it to the shop that changed te belt a month ago along with the tensioner. I just hope i dont have to pay for any other major repair....
  • For sale 1g coil pack
    Used 1g (91-94) coil pack and bracket. One stud to mount the harness is broken, but still has...
  • For sale 4G63 OEM Balance Shaft Delete Kit
    OEM Balance Shaft Delete Kit $40 + shipping and PayPal fees* includes crank spacerYou must...
  • For sale Evo viii fuel pump
    Used Denso Evo 8 fuel pump. Similar flow to the Walbro 190. Plug n play for 2G's. Been...
  • For sale 2g 2G Hatch Weather Seal ( no rips or tears )
    2G Hatch Weather Seal $45 + shipping and PayPal fees* no rips or tearsYou must be...
  • For sale 2g 2GA Eclipse Fog Lights & Brackets
    2GA Eclipse Fog Lights & Brackets $70 + shipping and PayPal feesYou must be registered to see...
