Tim Zimmer parts auction benefit
Seriously, I should buy the damn parts myself and resell them for a profit, they are all WAY BELOW my wholesale cost.
Come on you guys, like jump on this!!
Not sure how this auction looks on FB but thru Tuners I feel like I'm in a vacuum.
Anyway. I want to up my ante to $500 for the SB SS-TZ clutch.
K05048-SS-TZ | South Bend Clutch | We Motivate The Shiftless
South Bend Clutch offers new and rebuilt clutches ranging from OEM factory specifications to varying degrees of performance and heavy duty for all automotive, truck, and industrial applications.
www.southbendclutch.com
@jmelocik
FYI my email is not working so if needed, PM me through DSMTuners. Thanks
@jmelocik
Looks like that would reinstate you as the high bidder. I added a comment for your bid and tagged Paul and Joshua.
Volk metal Craft parts up for Auction: ALL BIDDING CLOSED ON THIS ONE
1G DSM Active Toe Eliminator (ATE) Kit (Current bid = $150)
1G DSM AWD rear Upper Control Arms - Curved version (Current bid = $300)
2G DSM solid front K-member bushing set (No bids yet)
2G DSM tubular rear Toe Arms (AWD or FWD) (Current bid = $250)
Any update on this item ?
I’m interested on 2g tubular rear toe from volks
@jmelocik
Congrats @Mello for submitting the highest offer on the SB clutch. I’m PMing you to forward Joshua’s contact info.
VERY VERY big Thank You to Josh Melocik, Quarter Master, Geoff Tickes, Paul Volk and the man this is all about, Tim "The Man" Zimmer for the fine equipment that I recieved from the auction. I don't think I ever seen anything so pretty in a clutch before.
Tim, this is for you!
You deserve my proceeds, god bless you! 🙏
Marty
Everybody else.......DROOOL!!!! ;)
Come on by and we will go for a spin :thumb:
With the clutch, be sure you use 1120A062 19.5mm flywheel bolts, star pattern, 35/70/100 ft/lb torque sequence with loctite red (262 or 263), and then the cover ARP bolts are star pattern, evenly tightened by hand and then 12-14 ft/lb with loctite blue (242 or 243).
With the alignment tool, grab a calipers and a roll of electrical tape and evenly wrap the tip until you are around 0.005" smaller OD than the alignment hole which if I recall is 0.750". Confirm before installation so you are prepared.
Use an OEM TOB and TOB clip, and a Competition Clutch forged clutch fork.
Copy that Tim! You are so helpful all the time! :thumb:
