Throttle Body Rebuild Kit
snowborder714
Moderator
16,181
380
Oct 15, 2006
Mechanicsburg, Pennsylvania
CURRENTLY OUT OF STOCK. I'm currently looking for a new seal supplier and will update you when I've got a solution.
My brother and I have been doing throttle body rebuilds for a few years now, but I know there's a lot of people out there who like to fix things themselves. So we are now offering a throttle body rebuild kit! This kit includes all the parts needed to rebuild a throttle body and eliminate any of those pesky shaft seal leaks that we all love so much. It eliminates the oh-so-common stripped screws by replacing the FIAV ones with allen head pieces and replacing the shaft screws with new ones.
Kit works with:
'91-'94 Non-turbo throttle body
'91-'99 turbo throttle body
Evo 3 throttle body
Kit contents:
(1) OEM FIAV gasket
(5) stainless steel allen head FIAV screws (with stainless steel lock washers)
(1) OEM BISS screw
(1) OEM BISS o-ring
(1) OEM ISC o-ring
(2) stainless steel allen head ISC screws (with stainless steel lock washers)
(2) stainless steel allen head TPS screws (with stainless steel lock and flat washers)
(1) stainless steel lock washer for shaft
(1) stainless steel jam nut for shaft
(2) stainless steel shaft screws
(2) shaft seals
Notes:
All hardware is 18-8 stainless steel.
FIAV screws will work with or without FIAV bypass plate.
ISC screws will work with black or tan ISC.
Kit options:
Mil.spec shaft seal rebuild kit
*Notes around mil.spec seals - http://www.dsmtuners.com/forums/bolt-tech/436875-mil-spec-throttle-body-shaft-seals-dont-fit.html
Extras! *NEW*
We now have shaft seal install tools available for sale. These will work with all seals, but are extremely helpful for the mil.spec seals. These will drive the seal in straight, which is key to preventing damage to the seal.
$15 + shipping
Or if ordering a mil.spec seal kit, $15 as shipping is already included in the seal kit price.
Kit and seal pictures:
Snowborder,
are the throttle body rebuild kits still available? Im looking for a kit to fit a 94 talon tsi awd. Do they come with instructions or a video? Thanks.
Are you able to get the seals or make a kit that will work for the 90 throttle bodies?
I did have the second seal that the '90 would use before (sold my last one a few months ago). But the FIAV gaskets are different and the screws are different lengths. It would take some research to see what all I'd need and honestly I don't get the interest in '90 kits that would make it worth it to offer.
Dang.... It was worth a try. Thanks for the response.
Snowborder714; Am looking for a kit for a 92 Laser 4G63T, Do you still have any available?
