1992awdlaser
- 3,051
- 26
- Dec 5, 2004
Wallace,
North_Carolina
I am thinking about using nitrous with my 50 trim on 110 octane or c16. It will be a wet kit and the car is not a daily driver. Do you think it will be able to handle a 50 or 75 shot. And what kind of et/mph should I look for with this setup. And what boost would be safe for it also with nitrous.
255lph fp
Perrin mbc
free mods
Buschur 3" turboback (no cat)
urethane motor mounts
Buschur o2 housing
k&n filter
Sbr cast exhaust manifold
PTE 1000cc injectors
Buschur fmic
Turbonetics evolution wastegate
Aeromotive fpr
3" gm maf sensor
SBR 3500 clutch
Act xact flywheel
AEM eugo wideband
Dsmlink
Sbr g50
FP2 cams
Stock block
I have all these parts listed but I might be missing something. If you don't see something that should be on there just ask. Thanks for the help in advance. My goal is to hit mid-high 11's. I am thinking about the nitrous so I can go against my friends rx-7 and have a better chance.
Also does anybody have any tuning tips if I decide to go with the nitrous. Like should I leave the tune alone and make changes as needed or should I richen it up a little for the first run. Should I lower the boost, if so how much. And anything else you might think I should do.
255lph fp
Perrin mbc
free mods
Buschur o2 housing
k&n filter
Buschur fmic
Aeromotive fpr
3" gm maf sensor
SBR 3500 clutch
Act xact flywheel
AEM eugo wideband
Dsmlink
Sbr g50
FP2 cams
Stock block
