LiquidX
DSM Wiseman
- 8,285
- 120
- Sep 19, 2008
Anywhere,
Pennsylvania
You can start by understanding my cooling setup before making comments that would otherwise become known and understood.
http://www.dsmtuners.com/forums/blogs/liquidx/2834-attacking-my-cooling-problem-part-2.html
For a while now, my engine bay has become dreadfully hot. Too hot to touch the valve cover, timing belt, intake manifold, and even my IC pipes. Water has dripped onto the head and it instantly boiled like it would do on the exhaust manifold. The upper coolant hose became rock hard and extremely hot while the lower hose is more pliable and pretty cool to the touch.
My exhaust manifold and external o2 housing are wrapped and so is my upper down pipe.
I came to 2 conclusions, either I have a blockage in my cooling system or my thermostat has become null-and-void. So today I went to do some testing to see if either would help.
I started off by doing a coolant flush using a tee adapter placed in the upper heater core hose and hooked up my garden hose to it. I also completely removed my thermostat prior to doing this. I opened up the radiator drain, turned on the hose and flushed it out until it came out clear. Tightened everything up, got the air out, added a little bit of actual coolant.
On my drive my temps got back up to where they were before and everything is still extremely hot under the bay and my coolant temps were hot enough (no actual data). Very displeased with this. Began to read up on how the system needs some back pressure so I installed a modified thermostat. Basically the spring section is cut out so you still have the plate to install.
Put that in and filled up with 90/10 water/coolant. I now have actual data.
This is with coolant offset on ECMLink v3 at +20*. Fans switched on via link.
Idle with fans on: 165*
Cruise with fans on: 180* max
Cruise with fans off: 190*ish
Coolant offset to 0* and fans switched off via link
Cruise: 210* and fans turn on and temps do not lower
Shut off the car, temps went up as they should, I turned on the fans and monitored my IAT. IAT temperature reached about 133* and the sensor is placed right after the FMIC. I know that the IAT temps will raise as well with a fan blowing on them but that is quite a bit of an increase.
Here is the question, does anyone have any insight to this? Could my water pump not be working as well anymore, could I still have a "clog" somewhere? I'll be taking out my AC condenser sometime in the next couple weeks and I'll try re flushing the system again.
I'm putting in a Mishimoto 143* thermostat Monday and if nothing else works, I'm going to consider putting in a colder fan switch and just bypass the ECU for the fans. I also have to do my timing belt soon and will grab a new water pump as well.
So please, any help would be good.
