1. Join the Community!
The Nissan Zeod from the Micra?
Posted by yldouright, Jul 9, 2019
Please Support Southbay Fuel Injectors
Please Support ExtremePSI
  1. yldouright
    yldouright Probationary Member
    6
    Joined Dec 27, 2018
    New York, New York
    For those of you that know the Zeod, it got ~400hp from an 88lb. 3 cylinder block. It occurred to me that their HR12Dxx line of engines might be suited to building a 400whp diesel from it. Why would it work? The engine is well balanced and can rev to 8800rpm without blowing apart. Its stock compression is 13:1, it's direct injected and it has VVT with a good ECU.
  2. rabenne
    rabenne Proven Member
    1,103
    300
    Joined Apr 21, 2006
    Racine, Wisconsin
    Cant wait to see it in your DSM...
    Street Build 342  5
    1996 Mitsubishi Eclipse GSX
    awd · automatic · 2G DSM
    Street Build 254  12
    1997 Mitsubishi Eclipse GST
    fwd · automatic · 2G DSM
    Street Build 7K  15
    1995 Eagle Talon TSi
    awd · manual · 2G DSM
    Loading...
  3. yldouright
    6
    Joined Dec 27, 2018
    New York, New York
    @rabenne
    We're quite a long way from there at this point. I posted this to see if anyone else saw the potential like I do.
  4. rabenne
    1,103
    300
    Joined Apr 21, 2006
    Racine, Wisconsin
    yea, I can imagine. The engine has potential. Is it a good swap option? That remains to be seen. Cant wait to see what you do! I am guessing the price tag will be prohibitive.
    Street Build 342  5
    Street Build 254  12
    Street Build 7K  15
    Loading...
  5. yldouright
    6
    Joined Dec 27, 2018
    New York, New York
    There are going to be some pricey items (>100lb/hr, wide dispersion injectors, 60gallon/hr, 60psi fuel pump, etc.) but considering what you'll end up with price/performance wise, I'd say it's a bargain. The engine weight savings alone will make a mundane car an 8lb/whp performer
  6. rabenne
    1,103
    300
    Joined Apr 21, 2006
    Racine, Wisconsin
    What do you expect to pay for one of these engines? How are you going to source it/who is going to sell you one?
    You can get >8 hp/lb out of a stock long block, so you must be getting this engine really cheap, right?
    Street Build 342  5
    Street Build 254  12
    Street Build 7K  15
    Loading...
  7. yldouright
    6
    Joined Dec 27, 2018
    New York, New York
    If you look up the HR12xx engines, you'll understand how cheap.
  8. motomattx
    motomattx Proven Member
    2,149
    798
    Joined Dec 9, 2010
    wampum, Pennsylvania
    If its aluminum I would say forget it, the cylinder pressures alone would take it out.
    Drag Race Build 3K  24
    1995 Mitsubishi Eclipse GST
    fwd · manual · 2G DSM
    Loading...
  9. rabenne
    1,103
    300
    Joined Apr 21, 2006
    Racine, Wisconsin
    Please share a link of one for sale. I still don't see it...
    Street Build 342  5
    Street Build 254  12
    Street Build 7K  15
    Loading...
  10. rabenne
    1,103
    300
    Joined Apr 21, 2006
    Racine, Wisconsin
    HR12DDT makes all of 114 HP... I am still missing something...
    Street Build 342  5
    Street Build 254  12
    Street Build 7K  15
    Loading...
  11. yldouright
    6
    Joined Dec 27, 2018
    New York, New York
    @motomattx
    I'm looking at that now and you're right. The net pressure ratio is going to have to stay well under 3. Any hint of flaw or weak spot in the metal and its kapow! It looks like 400whp is not attainable but 360 looks doable. The block does not seem to be the problem, it's the head.
    @rabenne
    Yes, I think you are. The ECU mapping and VVT can be optimized for diesel fuel to make the power. I was basing my numbers on the high VE and an expected 3.3 net P.R. Lots of potential here for those with some patience to study.
  12. rabenne
    1,103
    300
    Joined Apr 21, 2006
    Racine, Wisconsin
    Still missing it... You have done/said nothing to make me believe this would be a good idea. Yes the engine is impressive (when tuned by Nismo engineers), but you probably wont have access to their notes... The 1.2L from the Micra is a long, long way from being a DIG-T R engine. Good luck :thumb:
    Street Build 342  5
    Street Build 254  12
    Street Build 7K  15
    Loading...
Share This Page
ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RixRacing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory
