For 1990-1999 Mitsubishi Eclipse, Eagle Talon, Plymouth Laser, and Galant VR-4 Owners
  • Join the Community!
Please Support ExtremePSI
The cause of this type of grind?
my_gst95
567
Nov 13, 2002
Sacramento, California
I'm having some grind issues in 1st and 2nd on my 90GSX and I was wondering if you guys can help me figure out what part of the tranny it is:
1) At idle, if I ease it into either 1st or 2nd, it won't grind. But if I push the clutch down and immediatly put it into 1st or 2nd, it will 95% of the time grind. Normal driving from 1st to 2nd will grind also unless i really ease it and let the RPM drop by alot.
2) At idle, if I put it into 3rd, and then immediatly go into 1st (4th and go directly to 2nd) it won't grind at all. I guess it's still spining, and putting into 3rd/4th first stops the rotation for it to go into gear without grinding.
3) Downshifting from 3rd to 2nd doesnt 'usually' grind and if I rev match it will never grind.
I've tried adjusting the clutch rod under the steering wheel and it hasn't helped. It doesn't help my engagment point either since my clutch likes to grab really close to the floor.
Someone suggested that it might just be a bad clutch, or maybe even replacing the slave cylinder rod with the longer one sold at Dsmparts.com may help. Penzoil tranny fluid is in it now and I may go with the BG II if it would help any.
my_gst95
Defiant
DSM Wiseman
34,773
162
Jan 13, 2003
glorious Galt, California
That's because the gearsets are still "coasting". If you snub against 4th first, it'll brake the gears and stop the grinding.
There you go.
Which is just what you should do. Double-clutching helps even more.
90DSMTurboFWD
290
Nov 11, 2003
HawaiiUS
I have the exact same problem however instead of grinding from 3rd to second I have like a tight notch to get over. I have to really PULL the shifter into second. Its like I am pulling it into a really tight slot. Anyone know what this problem is? or any fixes?
madd1GNA
25
Dec 8, 2002
Louisville, Louisville_Ky.
I had the exact same problem and fixed it very nicely by replacing the master cylinder. It also reduced pedal pressure by a lot. good luck
Boosted Fabrication ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications MyMitsubishiStore.com OHM Racing Raven Fabrication RixRacing RockAuto RTM Racing SouthBay Fuel Injectors STM Tuned VR Speed Factory
