Resolved 1G Temp sensor
obx tsi
197
2
Dec 1, 2005
Manteo, North_Carolina
I have checked many post but am still unable to find where to buy this sensor. Napa is unable to find it. Thanks
When I web searched that number it didn't come up. Thanks
Are you looking for the one on the radiator? The pic you uploaded looks like a temp switch for a/c the one on the thermostat housing.
If you are looking for the one on the thermostat housing, look for it with the part number MB568959. Like the link below.
If you are looking for the one on the radiator, the part number is MB356704. (Not MD)
https://www.rockauto.com/en/partsearch/?partnum=MB568959
Found it. Typo in first replay was the problem. Thanks
Yeah there is a typo, MD instead of MB. But what I meant was just to make sure what you are exactly looking for. I don't know which one you are looking for. The both switches look similar but its temp range is different. So be careful, not to use a wrong switch on the radiator, otherwise the fan wouldn't turn ON at the right moment and the engine may be overheating.
It is the one directly below and slightly to the left of the thermostat cap.
You are talking about 1G and the one it goes where the red circle in the pic below? If so, the one you chose (MB356704) won't fit. What you want would be what I mentioned above. The part number MB568959. That's the one with BSPT thread with 115 degree C temp range.
