obx tsi
- 184
- 1
- Dec 1, 2005
Manteo,
North_Carolina
This is the sensor I'm looking for.
Are you looking for the one on the radiator? The pic you uploaded looks like a temp switch for a/c the one on the thermostat housing.When I web searched that number it didn't come up. Thanks
Yeah there is a typo, MD instead of MB. But what I meant was just to make sure what you are exactly looking for. I don't know which one you are looking for. The both switches look similar but its temp range is different. So be careful, not to use a wrong switch on the radiator, otherwise the fan wouldn't turn ON at the right moment and the engine may be overheating.Found it. Typo in first replay was the problem. Thanks
You are talking about 1G and the one it goes where the red circle in the pic below? If so, the one you chose (MB356704) won't fit. What you want would be what I mentioned above. The part number MB568959. That's the one with BSPT thread with 115 degree C temp range.It is the one directly below and slightly to the left of the thermostat cap.
Check Extreme PSI..Do you know where I can buy one?
