2G TEIN Flex Front Fitment
unplugme71
185
3
Apr 21, 2011
Central, New Jersey
For some reason the rears fit fine and the fronts are a bit short to bolt up. Anyone else have this issue?
I even tried to extend the shock body to the point if I turned it 1 more full turn the shock would remove itself front the lower piece and it still doesn't fit.
This is a 95 FWD
If your car is on jackstands put your jack under the suspension arm to gently lift it up so everything lines up. Also, tighten and torque the three top strut mount nuts last when the car is on the ground.
I'll give that a shot. I never installed suspension before that involved jacking the entire suspension assembly before to get it installed.
