jtmcinder
DSM Wiseman
- 5,402
- 96
- Nov 4, 2003
Iowa City,
Iowa
These questions are really (only) for people who have Tein Flex coil-overs on a 2G or someone like a vendor who has them in hand.
These questions only concern the front of the car (since this is where 2Gs have suspension-travel issues).
1) When the lower mount on the shock is set to make the shock body as short as possible, what is the distance from (a) the lip on the shock that sits on the top edge of the fork to (b) the top of the shock body? In other words, how long is the shock body as measured upwards from the top edge of the fork?
2) When the bumpstop is removed, what is the distance from (a) the lowest part of the spring-hat mount on the shock shaft to (b) the surface of the upper mounting plate that is in contact with the chassis?
These are the two values that are required to calculate the amount of suspension travel for any given amount of lowering of the car.
Thanks in advance.
- Jtoby
Thanks in advance.
- Jtoby
