Kryndon
- 944
- 591
- Jan 10, 2014
Bulgaria,
Europe
Hey all,
I have no one near me to consult with so I would like to ask you guys and gals. I'm in the process of rebuilding the engine and I took the flywheel/clutch out. The clutch/disc have done 12k miles without any issues and the flywheel was resurfaced before I put the clutch on.
I've done a few launches and drag passes since, and a lot of city/highway driving. I must say it has held up very well although the clutch pedal is stiff as hell because of the springs on the pressure plate. (It's a Competition Stage 2 clutch kit.) But otherwise I haven't had any issues at all. So when I took it out, I was almost shocked at how flat the friction disc has gotten (the pads are almost flush with the channels), and both the flywheel and pressure plate surfaces have lots of spots (guessing from launches) and I have no idea if this is still okay to use or if it's broken.
I would like to hear your opinions, but keep in mind that given my location, I cannot find a new flywheel or clutch kit, nor do I have the money. Worst case would be to order from the USA which would make it 2x more expensive. I was thinking of maybe lightly resurfacing both flywheel and disc, or just passing it with some sandpaper by hand?
