highlandgst
- 805
- 0
- May 11, 2009
miller,
Indiana
Ok so here it goes I've gone through just about everything . At first my car would start if i jumped it but it would barely run and if i turned the brights on it would bog down the power like the battery was draining and the alt was not working. So I went through every step with that ( taking the alt in checking fuses and so on . )
A day later I came to find out my hot cables that go from the fuse box to the battery were melted . So i replaced those ,now I get NO POWER what so ever no dome lights no door ding do keyless unlocking . NOTHING . I tryig the fuses , all good , the wireing was go the rest of my wires in the fuse box are not melted .I pulled my ECU and it does no have any burnt chips or diodes does not smell of burning circuits either. There are no frayed or broken lines anywhere within sight and just short of pulling the entire harness I've checked as much as I can . Is it possible that the ECU could just have gone bad without frying anything ?
