Stock GSX detonating like crazy
sallystrothers
Dec 12, 2002
A girl I work with has a bone stock 1998 GSX w/70,000 miles. She complained it has a problem. I took it out for a test drive and I am sure her problem is detonation/knock response. Why would a stock GSX have large amounts of detonation (happens almost every time turbo hits max boost)? I told her I would replace the spark plugs w/ colder ones, clean out carbon deposits w/ seafoam, and put 2 gal xylene in gas tank. I know this might help reduce detonation a little but there must be some underlying problem. Maybe air pocket in cooling system? Base timing off? What is the deal?
check vaccuum lines going to fuel pressure regulator, if the fuel is wacked out then the car runs lean and so for detonates.
Car has good idle so if a vacuum line were off the FPR it would have even worse performance than it is at now. Good idea and keep them coming!
