1. Join the Community!
2G Starter relay/Ignition Switch
Posted by drthorp, Nov 21, 2019
Please Support Southbay Fuel Injectors
  1. drthorp
    drthorp Proven Member
    56
    24
    Joined Oct 22, 2019
    Trussville, Alabama
    First off, just a brief description of my car and it's issue... It is a 1996 GSX M/T with 156K on the chassis/electronics. I have been starting it and driving it in the process of discovering/repairing some oil leaks. There has never been an issue with starting it (no starter grinds or power issues) until yesterday. I go to start the car and nothing happens except the fuel pump noise from the upgraded walbro pump. I smell gas and everything so its getting fuel but there isn't a single noise from the starter. Since I never had any kind of evidence from the starter getting bad, I decide to investigate the relay first. I dig into the console and find two relays next to each other(see picture). And I am not sure which is the starter relay. I searched the forums first and found conflicting info so I guess I have a couple questions:
    Which of these relays is the starter relay? And does this issue sound like a relay issue, and how does one bypass this relay? Could this be an ignition switch? or does the fuel pump operation signify a good ignition switch? Thanks in advance.
    207  6
    1996 Mitsubishi Eclipse GSX
    awd · manual · 2G DSM
    Loading...
  2. JPenny
    JPenny Proven Member
    138
    39
    Joined Feb 24, 2016
    Corpus Christi, Texas
    More than likely this is to simple to be your fix but check the little signal wire on top of the starter if the clip came off it will never start. Do you have access to a multimeter you can check voltage at the relays regardless of which one because I'm not sure myself. Also there should be a small audible click or you can feel the click when a relay is activated. Those are a few things I would check that are simple and fast. Sorry for the long message thank you for your time, Jason Penny
    157  6
    1996 Mitsubishi Eclipse GST
    manual · 2G DSM
    Street Build 2K  4
    1997 Mitsubishi Eclipse GST
    fwd · manual · 2G DSM
    Loading...
  3. drthorp
    56
    24
    Joined Oct 22, 2019
    Trussville, Alabama
    I do have a multimeter and I guess ill check into the signal at these relays. I definitely hear ONE click , but I believe one of these relays is for the fuel pump so that may be the click that im hearing. After work today Ill be checking to the physical condition of the starter and its connections, maybe something came loose on the drive over that day. Thanks for the reply! Any and all info is appreciated.
    207  6
    Loading...
  4. miguelmcv
    miguelmcv Supporting Member
    2,327
    159
    Joined May 3, 2009
    Fresno, California
    The relay with two big black wires is the one for the starter. It’s black with red stripe and black with green stripe.
    Ike Jpenny said check if there is current at the starter wire when cranking.
    There are several spots to check.
    1. Clutch switch
    2 Relay (which you are looking at)
    3 connector at the wiring harness. (There is a Connection in the. harness and is between the starter and battery, is in the harness),check if it didn’t got disconnected.
    4 starter wire. Check is not off the stater.
    Street Build 526  1
    1997 Eagle Talon TSi AWD
    awd · automatic · 2G DSM
    2K  0
    1995 Mitsubishi Eclipse GST
    manual · 2G DSM
    Loading...
  5. drthorp
    56
    24
    Joined Oct 22, 2019
    Trussville, Alabama
    Thanks for the reply! I forgot to mention that I already disconnected the clutch switch before all this. Ill be sure to check these signals and connectors and give a quick update on this. Just to clarify...the on the the driver's side is the starter relay and the other is the fuel pump relay?
    207  6
    Loading...
  6. rabenne
    rabenne Proven Member
    1,313
    480
    Joined Apr 21, 2006
    Racine, Wisconsin
    That's not a good thing... where is your fuel leak coming from? I know this is off topic, but you shouldn't smell fuel from having the pump running. You probably have a leak.
    What kind of hoses/connections did you use?
    283  7
    2008 Lancer Evolution MR
    awd · automatic · Lancer Evolution
    Street Build 8K  19
    1995 Eagle Talon TSi
    Street Build 494  5
    Loading...
  7. drthorp
    56
    24
    Joined Oct 22, 2019
    Trussville, Alabama
    Update: Bypassed the relay and actually got a click out of the starter, replaced the starter solenoid and cleaned up the contacts, and we have lift off! thanks guys...
    207  6
    Loading...
    rabenne likes this.
Share This Page
ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RixRacing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory
