1. Join the Community!
1G Starter Issue
Posted by hoonigane, Mar 28, 2020
Please Support VR Speed Factory
Please Support ExtremePSI
  1. hoonigane
    hoonigane Proven Member
    102
    10
    Joined Jan 4, 2018
    Siauliai, Europe
    Couple months ago my starter died. It made no noise at all. I pulled it out and one wire to carbon brush was broken so I replaced it. After a month the same issue appeared. I drove to a shop (it started perfectly on my way to shop) and when i wanted to go back it again made no noise at all. I was fed up and didnt wanted to fix it myself so just push started it and drove to mechanics. Now couple weeks later same sh** happened. It just clicks when you turn the key and nothing happens. Any ideas what could be causing this problem? I have no interest in fixing starter every 2 weeks.. Also I should point out that first time it happened it didn't happen suddenly like recent 2 times. For couple weeks the starter made clicking sounds but after couple seconds it would turn over. Now its sudden and no sound at all
  2. ThunderChild
    ThunderChild Supporting VIP
    2,861
    950
    Joined Jan 5, 2012
    Rathdrum, Idaho
    Check the connections for the main power feed wire and make sure the main ground wire is attached to the starter bolt. Ensure both are corrosion free and have bare metal connections to their respective areas. Issue you're having sounds like poor grounding to me.
    Street Build 593  3
    1990 Plymouth Laser N/T
    fwd · manual · 1G DSM
    620  8
    1987 Toyota Pickup/Hilux
    awd · manual · Misc Vehicles
    Street Build 1K  7
    1997 Mitsubishi Eclipse Spyder GST
    fwd · manual · 2G DSM
    2K  0
    1992 Eagle Talon TSi AWD
    manual · 1G DSM
    Street Build 3K  10
    awd · manual · 1G DSM
    Loading...
  3. Sjd6795
    Sjd6795 Proven Member
    381
    83
    Joined May 14, 2014
    Wilsonville, Oregon
    Trace the wiring all the way back, make sure there isn't any other damages. After that check fuses and starter relay.
    Street Build 440  11
    1997 Mitsubishi Eclipse GSX
    awd · manual · 2G DSM
    Sjd6795
    Street Build 1K  0
    1991 Eagle Talon TSi AWD
    manual · 1G DSM
    Loading...
    hoonigane likes this.
  4. hoonigane
    102
    10
    Joined Jan 4, 2018
    Siauliai, Europe
    Thanks for fast responses guys will check wiring tomorrow. Also I wanted to ask if what I did could have anything with this issue. On the firewall just behind the battery there is a hole for all the wiring to go. When I installed sub I put pretty beefy wire and I ran it together through that hole, but because the wire was fat I had to remove rubber around that hole and just left that white plastic thingy. This seems far reach but have to ask
  5. TK's9d2TSi
    TK's9d2TSi Supporting Member
    2,850
    1,058
    Joined Sep 11, 2017
    Cincinnati, Ohio
    Is it manual? If so, something you might want to check before you trace wires is to make sure the clutch pedal switch is fully depressed. There’s a rubber grommet that’s on the pedal between the switch and the pedal assembly. When that switch isn’t fully depressed, the relay inside clicks as well. But if you’re 100% it’s the starter that’s clicking, then you don’t have to check this.
    If it’s auto, check the neutral safety switch. Idk where that is but I’m sure you’ll be able to do a quick search.
    Btw, you’re hearing one click and not several clicks?
    344  3
    2000 Jeep Cherokee Sport - Classic
    awd · automatic · Misc Vehicles
    370  4
    93 Civic 4 Door -sold-
    fwd · manual · Misc Vehicles
    Street Build 3K  6
    12.625 @ 111.42 · 1G DSM
    Loading...
  6. steve
    steve DSM Wiseman
    12,840
    613
    Joined Feb 3, 2002
    Boulder, Colorado
    If there's a way to push start an automatic, I'd like to know the trick. It could be handy in the future.
    The other points were great.
    4K  0
    1991 Mitsubishi Eclipse GSX
    manual · 1G DSM
    Loading...
  7. TK's9d2TSi
    2,850
    1,058
    Joined Sep 11, 2017
    Cincinnati, Ohio
    :ohdamn::ohdamn::ohdamn:
    344  3
    370  4
    Street Build 3K  6
    Loading...
  8. hoonigane
    102
    10
    Joined Jan 4, 2018
    Siauliai, Europe
    Just a single click. Couldn't check wires it started snowing yesterday :(
  9. hoonigane
    102
    10
    Joined Jan 4, 2018
    Siauliai, Europe
    Where iš starter fuse?
  10. hoonigane
    102
    10
    Joined Jan 4, 2018
    Siauliai, Europe
    Found The issue thanks guys. The + wire to The starter is broken
  11. hoonigane
    102
    10
    Joined Jan 4, 2018
    Siauliai, Europe
    The weirdest thing was that - wire wasnt connected anywhere. I cant explain that
  12. TK's9d2TSi
    2,850
    1,058
    Joined Sep 11, 2017
    Cincinnati, Ohio
    We’re glad you found it
    344  3
    370  4
    Street Build 3K  6
    Loading...
  13. hoonigane
    102
    10
    Joined Jan 4, 2018
    Siauliai, Europe
    Finally got that little metal connector for the wire. Im pretty sure but just gonna ask because - wasnt conected anywhere - can you ground the starter to the same 1 of 2 bolts that holds the starter?
  14. 1990TSIAWDTALON
    1990TSIAWDTALON Moderator
    5,222
    2,542
    Joined Nov 14, 2013
    Independence, Kansas
    You SHOULD ground it to one of the starter bolts so it has a very good connection on the ground side. That is the proper place for 1 of the grounds.
    Street Build 4K  29
    14.74 @ 117.04 · 1G DSM
    1K  14
    1990 Mitsubishi Eclipse GSX
    703  18
    1967 Chevrolet Camaro RS
    rwd · automatic · Misc Vehicles
    Street Build 970  7
    1998 Eagle Talon TSi
    Street Build 6K  13  25
    1990 Eagle Talon TSi AWD
    13.620 @ 108.460 · 1G DSM
    Loading...
    hoonigane and ThunderChild like this.
Share This Page
ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RixRacing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory
