Grimis
- 1,096
- 12
- Sep 5, 2003
Jersey Shore,
Pennsylvania
Simple Easy Answer :NO
They are diffrent. It sucks
Does anyone have pictures that can show what exactly needs to be done to modify an Automatic shell to recieve a Manual Trans/Clutch pedal assembly? This thread has everything pretty clear, but I'm a little uncertain of how you go about mounting up the clutch pedal.
I don't have the two cars in the same location to compar differences right now either. Thanks.
Cool. Thanks for the fast response. Also, aside from removing the TCU, can you retain the stock auto wiring harness? Basically, I'm just swapping my 1g 6 bolt/mt trans into an auto 92.5 (stock 6-bolt), so it should still all work, with the removal of the TCU, right?
-edit-
my manual Eprom ECU is going too.
Okay, so I finished pulling apart my 1g dead shell for all the necessary parts. Not too difficult to pull the pedals, just a PITA working around all the wires/heat ducting.
This is mainly for anyone who has done a 1g swap, but do you know if the manual ECU will run in the auto wiring harness with the TCU removed?
Just curious and want to find out for sure before I start ripping this other auto Talon apart.
Also, does anyone know what all the little 'boxes' are behind the center console? Not the ECU, but smaller, black and silver boxes that attach into the wiring harness. I couldn't find any idea as to what they might be for... I'll post pictuers if needed. Just curious what they are and if they're worth anything and/or might need to be swapped as well.
Featured Products from our Supporting Vendors
