1. Join the Community!
Stainless coolant lines necessary?
Posted by crazyquik22023, Jan 7, 2010
Please Support Morrison Fabrications
  1. crazyquik22023
    crazyquik22023 Proven Member
    610
    5
    Joined Sep 14, 2008
    Akron, Ohio
    So i just took off my E316g and im putting on a PTE 6052 t4 and i was wondering do u think it would be a big deal if i just used rubber coolant feed/return lines?? or do u think going stainless steel will really be worth it? prob been debated b4 but can't find any good threads on it so just looking for ## opinions thanks.
    850  0
    1998 Mitsubishi Eclipse GST
    12.900 @ 115.000 · 2G DSM
    Loading...
  2. LiquidX
    LiquidX DSM Wiseman
    6,607
    106
    Joined Sep 19, 2008
    Anywhere, Pennsylvania
    Just use the rubber coolant line as that's what it's used for. Unless you want to got for some "bling" then you could buy some fitings and thread the pipes.
    Street Build 3K  0
    1997 Eagle Talon TSi AWD
    manual · 2G DSM
    Loading...
  3. nyTalonTsi
    nyTalonTsi Proven Member
    446
    Joined Sep 5, 2008
    Buffalo, New York
    I'd upgrade them if their worn. They possibly might be 12 years old but if their fine, i guess you'd be safe.
  4. crazyquik22023
    610
    5
    Joined Sep 14, 2008
    Akron, Ohio
    I'm definetly goin to upgrade them just wanted to know whether i should upgrade cheap w/ rubber or go expensive with the stainless steel. i'm leaning toward just using the rubber ones.
    850  0
    Loading...
  5. BoostFrenzy
    BoostFrenzy Proven Member
    794
    4
    Joined Sep 29, 2006
    Santa Monica, California
    Stainless lines for the coolant feed and drain would mean no leaks as long as it is properly tightened. Rubber ones can crack or melt due to heat and time. Another option is something similar to SS. Push lock. IMO, a little sturdier then regular coolant lines and can be easily swapped if something does happen to them. Middle ground if you will.
    971  0
    1998 Mitsubishi Eclipse GSX
    · 2G DSM
    Loading...
  6. brute
    brute Proven Member
    1,515
    41
    Joined Jun 29, 2005
    San Antonio, Texas
    I would say when you have it all apart like this, just do anything that you can't do easily down the road.
    So I vote stainless.
    If you're on such a tight budget, wait a bit and buy what you really want (and may potentially need). Rubber is pretty good, but you can't get much better than stainless.
    510  0
    1991 Mitsubishi Galant VR-4
    manual · Galant VR-4
    Loading...
  7. crazyquik22023
    610
    5
    Joined Sep 14, 2008
    Akron, Ohio
    i agree with u completely, im actually not on a tight budget at all i just didn't really want to have to thread the thermostat and water pipe for the ss line an fittings. but thanks for the info everyone
    850  0
    Loading...
  8. brute
    brute Proven Member
    1,515
    41
    Joined Jun 29, 2005
    San Antonio, Texas
    Tapping something may seem like quite a chore, but once you do it a few times (correctly!), you will see it's really not a problem.
    I would rather spend 10 minutes tapping something now than an hour taking it all apart to replace a rubber line down the road.
    510  0
    Loading...
  9. crazyquik22023
    610
    5
    Joined Sep 14, 2008
    Akron, Ohio
    very true thanks for the input im prob gonna end up tapping it.
    850  0
    Loading...
Share This Page
ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RixRacing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory
