Squeak coming form belts?
MikeGsT69
35
Mar 26, 2003
I had a squeak coming from one of my belts it would squeak pause squeak pauseand so on i thaught it just needed some lubrication so i bought some lubrication spray thats supposed to stop sqeaks put some on it stopped for a sec and now a got a constant loud squeak at idle and it gets a little lower when i drive what is it on how do i fix this problem
Tighten your belts :thumb:
I've found that it's usually better not to use any type of belt-grip (which I assume is what you're talking about by the term "lubrication"). Just get a decent belt if it's old (Dayco is a pretty good brand), and replace it and tighten it up to factory specs. If you don't know how to do this, just buy the belts, take it to a shop, and they shouldn't charge an arm and a leg to do it, also, it should take a relatively quick time if they don't have too many people waiting.
Hope this helps :thumb:
  • For sale 650cc injectors
    Fic 650cc injectors $70 plus shipping and pp fees
    • Fully built dsm
  • For sale 2g Rear o2 sensor
    2g eclipse rear o2 sensor
    • Dryppical
  • For sale 2g Valve body
    2g eclipse valvebody and solenoids
    • Dryppical
  • For sale 2g Act throw out bearing
    • Dryppical
  • Wanted 2g Eclipse ignition actuator pin
    You must be registered to see element.Looking for this pin that goes into the ignition assembly...
    • Markhamx
