sputter between 5000 and 7000 rpms
Rsktakr
33
Jan 27, 2003
ok guys im stumped on this one.. the other day i put B37 race gas (118 leaded) in my car and changed my afc and vpc settings and turned up the boost and when i get on it a sputter and some small backfires occur from 5000-7000 rpms. my setup: buschur 20g, tial 40mm external, 3 inch turbo back, indy race cores FMIC, tial bov, 255hp pump, 650 injectors, SAFC, VPC, web street grinds, pocket logger. NOW i was wondering if my coil packs could be going bad cause my fuel trims are ALL 118, knock sum is 1 or 2.. 4 at the most, and when i richen it up till its to rich, it still does it and it still does it when i lean it out until i start to knock more. i have magnacores on my car and i had a extra set laying around and checked my spark plug gap( BPR7ES's) and set it at 32. i thought since i turned the boost up to 28-29 that it would be to much cylinder pressure and blow the spark out.. still did the same thing.. turn the boost down.. STILL the same thing..and NO codes on my datalogger.. ive run this gas b4 and NEVER had this problem and if you guys think its my ignition then what is a good setup w/ a decent price, how about the extreme setup and is it any different as in good versus the stock setup we have?? i have a 90 TSI AWD.. any of your help/insight would be great email to [email protected] if you can.. thanx:talon:
I'm thinking it's an ignition problem, too. First get new plugs and wires. Ditch those Magnacores and get some trusty NGK wires. Get BPR7es plugs and gap them to .028 .032 is a little big for even 18 psi. Try that first before you do any ignition upgrades, the stock ignition is plenty strong enough, assuming there's nothing broken.
i allreaedy tried the new plugs (bpr7es's) and right now they are gapped at 32 and on race gas (28psi) and put in different magnacores and STILL sputtered even when i turn the boost down to 24 or so and play w/ the afc and vpc setting it seems to sputter no matter what.. so im guessing something to do w/ the ignition . and i cant remember the name of that other part that is right by the coil pack ..the transistor?? anyways im not sure which setup to go w/ but im seriously looking at the extreme kit..i found a guy that i can get the whole setup from for around $300 shipped.. again any info or insight would be appreciated.. thanx
no one has any idea what this could be????? i put a different coil, and plug wires in today.. same damn sputter.. tomarrow is fuel filter.
try the plug gap a .028 i had mine at .32 and at 22 psi even lower got a lot of sputter. Just give it a shot its a 5 min job.
  • For sale 4G63 Parts
    Transmission starter plate fits 2G DSM 7bolt engine for Auto AWD or FWD and FWD Manual...
    • Dsm_canadian_mike
  • For sale 1g coil pack
    Used 1g (91-94) coil pack and bracket. One stud to mount the harness is broken, but still has...
  • For sale 4G63 OEM Balance Shaft Delete Kit
    OEM Balance Shaft Delete Kit $40 + shipping and PayPal fees* includes crank spacerYou must...
  • For sale Evo viii fuel pump
    Used Denso Evo 8 fuel pump. Similar flow to the Walbro 190. Plug n play for 2G's. Been...
  • For sale 2g 2G Hatch Weather Seal ( no rips or tears )
    2G Hatch Weather Seal $45 + shipping and PayPal fees* no rips or tearsYou must be...
