Please Support Morrison Fabrications
Please Support Rix Racing
Sport Compact Car
for those who didnt buy it. and wont.. but want to read the article on the 2G.. here it is.. i type 100wpm. and was practicing cause i had a lot of time on my hands and was bored.. :)
Subtle Impact
Serious power, modest package
BY JOSH JACQUOT
Sport Compact Car - Nov. 2003 - Vol 15, No. 11 Pg. 99
The formula for making a second-generation DSM fast was written years ago. It goes something like this: Big turbo, big injectors, magic electronic box. However, the formula for making a second-generation DSM fast and subtle is still being carefully honed on the streets of Southern California. There are plenty of tasteless Eclipses and Talons roaming around, with their stereos blasting and their body kits dragging on every driveway. Too often, any hopes the owner had for performance were lost in the quest for bling-bling supremacy. With a sleeper, efforts are focused on going fast rather than looking brazen. Since surprising the unsuspecting is the sole purpose for a sleeper, picking the right car is critical.
Any real sleeper has three decisive characteristics. First there’s abundance. One must pick a car that is readily available and easy to find parts for. And it doesn’t hurt if there are already thousands of them roaming around to make your ride even less obvious. Second, starting with a capable platform is vital. After all a sleeper must be able to make gobs of power in a benign package. Third, and this one is critical, a sleeper must be overlooked by anyone who might care—not being noticed is a must. In other words, the Mitsubishi Eclipse GSX is the perfect candidate.
Just ask Ronnie Diaz. He’s the owner of this 1997 Eclipse and is responsible for both its looks and performance. The former remains fairly tame. The latter doesn’t. Any real DSM enthusiast knows how capable these cars can be with only a few effective modifications. The ubiquitous Eclipse was the perfect choice for Diaz, who knew its abundance and familiar looks would help it fly under the radar of other enthusiasts.
He began his adventures into the world of DSM tuning in an Eclipse GS-T but quickly tired of the front-drive grip issues. After about three months of searching, he found the Eclipse on these pages and began making changes to suit his unassuming taste. However, before getting too radical, he went to the track armed with only a boost controller and stock turbo. The result was a 13-second time slip and we’re guessing one seriously overworked turbo.
Diaz knew he’d topped out the stock turbo’s potential and went to Road/Race Engineering in Santa Fe Springs, California for more power. He left with a Mitsubishi 16G turbo that helped get the car into the high 12-second range down the 1320, but that clearly wasn’t enough. Another trip to RRE left a Mitsubishi 20G hanging off the Eclipse’s exhaust manifold—a surefire way to improve power. The quarter-mile time dropped again to 12.30 seconds at 110mph. By now, the car had certainly achieved sleeper status—deep into the 12s and still looking relatively stock. But Diaz wasn’t finished. A third replacement turbo was in order and with it came a host of other changes.
In its current form, the Eclipse uses a Turbonetics T3 exhaust manifold and Tial 35mm wastegate with the Turbonetics t04B ball-bearing turbo. The turbo feeds a Greddy front-mount intercooler via plumbing from RD Engineering of Oxnard, California, which houses a blow-off valve from a first-generation DSM. A K&N filter replaces the stock Eclipse airbox. Downstream of the turbo, there’s an RSR turbo-back exhaust. However, Diaz stuck to the sleeper theme by replacing the stock melon-shooter exhaust tip with two less conspicuous tips designed to look stock.
Several upgrades were made to help the engine keep up with the added flow. A Denso 150 liter per hour fuel pump and 660 cc/min injectors provide additional fuel. A Greddy Profec B boost controller ensures manifold pressures appropriate for the 4G63’s entirely stock bottom end while an A’PEXi Super AFC modifies the airflow meter signal to the stock ECU.
Subtlety was the name of the game when it came time to replace the wheels and tires—no chrome monsters here. Enkei RS-Evolution wheels sized 17x8-inches replace the stock rollers while 225/45-17 Falken Azenis tires are enlisted for grip duties.
Suspension upgrades are mild, with KYB AGX shocks replacing the stock dampers and Neuspeed race springs mildly lowering the car. AEM 12.8-inch front roters are perhaps the only not-so-subtle upgrade visible from the street.
Inside, there are relatively few giveaways that this is a special machine. Autometer boost and EGT gauges are mounted to the A pillar while the boost controller sits out of the way on top of the steering column. The S-AFC fuel controller hides in the glove box.
Diaz, who runs RD Engineering, handles the tuning on the car himself and intends to run 11-second quarter mile before he’s finished with the Eclipse. He thinks his current hardware will do the job despite the engine’s stock bottom end. With near-stock appearance down to the exhaust tips and the potential for an 11-second pass on the horizon, Diaz is clearly writing formulas of his own.
1997 Mitsubishi Eclipse GSX
Engine
Engine Code: 4G63
Type: Inline four, iron block and aluminum head, turbocharged and intercooled
Internal Modifications: NONE
External Modifications: K&N air filter, Turbonetics T04B ball-bearing turbo, Turbonetics T3 exhaust manifold, RSR 3.0-inch turboback exhaust with dual semi-stock tips, Tial 35mm wastegate, Greddy FMIC, stock 1G DSM BOV
Engine Management Mods: Denso 150 LPR fuel pump, Denso 660cc/min injectors, A'PEXi Super AFC
Drivetrain
Layout: Transverse front engine, all-wheel drive
Drivetrain Modifications: ACT 2600 with street disc
Suspension
Front: KYB AGX shocks with Neuspeed race springs, 20.6-mm RMDSM anti-roll bars
Rear: KYB AGX shocks with Neuspeed race springs, 20.6mm RMDSM anti-roll bars
Brakes
Front: AEM 12.8-inch rotors, stock calipers, Porterfield RS4 pads
Rear: Stock
External
Wheels: 17x8-inch Enkei RS-Evolution
Tires: 225/45-17 Falken Azenis Sport
1/4 Mile Time
12.30 @ 110mph with old 20G setup (stock manifold)
If anyone thinks a 2g is a sleeper, they are retarded. Anyone who knows anything about fast cars at least recognizes a DSM and the typical clues....especially a 2g. They did showcase a real sleeper, however, the Hyundai 4G63T'd. Too bad it's in a mag, now more people know about it.
Tom
more people may know about it but how many people in that guys area are gonna quit underestimating his car. people will probably still try it thinking they can beat it only to have their asses handed to em. the only 2g that can really be a sleeper would have to be an rs with a stage 3 or above turbo and a well tuned engine that looked completely stock cuz everyone knows we rs's are slow stock:dsm:
Have to disagree, CRXs are the ultimate sleeper cars.
you know i have been looking for a 97-99 eclipse gsx in silver black or white, in houston do you know how hard it is to find a gst let alone a gsx in those years? i got my 98 gst spyder and was stuck with an auto cause thats the only 97-99 2g turbo convertible around here blah but soon a 97-99 gst will be on the list
Nope, Late 80's Dodge Colt hatchbacks/Mitsu Mirages > CRX's.
Bolt in 4G63 and no one knows about them?
:shhh:
i think the 2G is a sleeper after FnF came out and people who dont know thought of the car as a joke.. that and there seems to be more slow n/ts ont he street than fast turbo 2gs.
