mitsukid02
- 88
- 0
- Dec 29, 2011
Boston,
Massachusetts
Hey everyone! So i have my MAP OMNI 4-bar sensor, and GM IAT sensor. The way i set up SD on my lancer was to simply take out the stock MDP sensor, and replace it with the new OMNI 4-bar MAP sensor (i have an aftermarket alum IM so i plan on drilling and tapping to mount it to the IM), and the factory harness should plug in correct? and then fit the IAT to the UICP after the BOV, and wire it up to the ECU... Is this the same for the 2G 6-bolt setup??
Also, once i have the MAP installed, and the IAT wired up, do i simply enable SD tuning in ECMlink and im good to go, or will i need to really mess with the tune to get the car to idle and run ok? Thanks guys!
