slips69
- 10
- Oct 13, 2019
magee,
Mississippi
Hi my name is shaun I have a 96 Mitsubishi eclipse gs 420A with some issue's. My car runs for 15mins and just dies, it'll start right back up but then dies. I've noticed that the cooling fans don't come on when engine up to temp and top rad hose very hot lower one cold to the touch. So I've replaced both coolant sensors checked the wires for week spots checked grounds, checked the relays replaced thermostat replaced radaitor, rad cap, water pump, cam sensor, crank sensor, coil pack, wires, spark plugs. Scaned the car and p1390 was shown but i accidentally erasesd the code. I believe that I have 2 issues a faluty ecm and a bad block cause a so called friend use a drimel tool on the surface deck around cylinder 1-2 so i need to know could i use a 05 block from a neon and two sould I buy a a/fx preformance ecu instead of factory one that i would half to take to the dealer and get reflashed?
