2gjlc
- 119
- 19
- Dec 12, 2008
29 Palms,
California
I wanted to hear some thoughts on running a smaller cam to get back some spool time when upgrading to a larger turbo. My mod list is up to date. I have a 2.3 with GSC S2s and a HX35. I've reached the limits of the turbo in the bolt on housing and I'll be moving to a 60mm HX40. This is a street car and I'd like a broad powerband. I could be wrong but from what I've read it seems the turbo will affect the powerband much more than the cams. So would going to a set of S1s or similar kelfords help a little with spool? I lost about 400rpm in spool going from some Comp 100s/FP1s to these S2s and it was a great trade off for the mid and higher rpm power on the HX35. Would adjustable cam gears be a better option? I've read the thread that discusses cam timing and adjusting the cam gears to get back some spool so if these cams are better suited for my application with cam gears I'd consider that. Thanks
