VivaLaOC
- 121
- 25
- Mar 16, 2021
La Grande,
Oregon
The other day when I was driving I came to a stop after driving on the freeway and was in neutral and ebrake was on and I started to hear a knock like sound almost like a belt smacking somewhere I thought the timing belt was loose but I checked on it and got it to TDC and it was tight and timing marks were perfect. I'm still hearing the knock though and I noticed oil pressure was somewhat low but my oil pressure wiring isn't the best either so it could be that too. I'm gonna do an oil change tomorrow and see what its looking like, I just really hope I didn't spin a bearing, but I also don't run anything over stock boost and as far as I know everything internally engine wise is stock. The only things I've done is master and slave cylinder, aftermarket boost guage and an MBC but its set at stock boost I got them and installed those two things I have a FPR and 255lph fuel pump that aren't installed.
