mindset
- 1,853
- 7
- Jan 3, 2009
Brunswick,
Ohio
Speaking of water cooling I got another crazy idea. Does anybody watch the show Son's of Guns on the Discovery Channel? They did a water cooling system for a constant fire m16. They wrapped a coil of copper tubing all around the barrel and ran water through the system. Without the cooling system the barrel reached temps of 725 degrees. With the cooling system they had a 40 percent reduction in temperature. Now keep in mind that reduction is after firing 300 rounds constantly. After firing only one clip the barrel stayed at 82 degrees. They also used a water box. On a water to air system you use a radiator for the water which would reduce temps more than just a bucket of water would. We already have water to air intercooler set ups but they use a tiny intercooler integrated into the intercooler piping. You also have to pack the system with ice between runs to truly get it cool. If you had a hot pipe set up like the one pictured below and wrapped the whole pipe with copper tubing would it cool the system enough for a street car? I was thinking of trying it out but that's a lot of money to spend if it fails. Someone that already has a water to air intercooler set up could easily go out and buy 50 ft or so of copper refridgerator tubing, and wrap it around their intercooler pipe. Then just hook up your water pump to the copper tubing and send the water through the system. Here's a link to a quick video in case you haven't seen the show before.
YouTube - Watercooled M16
And Lucas English's Car:
I completely thought of this 3 years ago. Shoot me now.
