PearlSweatshirt
- 140
- 2
- Dec 10, 2013
Georgetown,
Kentucky
Note: This feature currently requires accessing the site using the built-in Safari browser.
Thank you. I didn't know it was bolted I will get to that!From the inside, two bolts. Take the center console out and the driver side console side plastic. Should be able to pull it through from under the hood once it's loose.
Yah what I'm hoping is that when I yanked it outta gear that the cable gave before the following parts did. Which I think is how it went because the ends on the transmission where screwed. I pulled the rubber sleeve down and some of the cable dismantled itself and was hanging halfway offAnd good luck. I'm hoping the shift fork isn't broken. Takes a lot to pull a cable apart.
