nh98gsx
- 109
- 0
- Feb 8, 2003
about a month ago my crank pulley separated, causing my ac belt to break, it then worked its way behind the timing belt cover wraped itself around the crankspindle jumping the timming and kaboom.
I finally got to see the valves today and in #2,3,4 all the rods were bent in number 1 cyl. one of the exahust valves had snapped right where the valve stem starts the valve head then embedded itself in the top of the block, i could even budge it.
Any way after much consideration i went w/a completely rebuilt ATK motor and there is a recommended 500 mile break in period, should i not put my intake and BOV (injen and turboxs H34) back on till after the break in?
It is good to be mobile.
