...send it on an SRS...
focusedrage
1,053
Aug 3, 2002
Laytonsville, Maryland
just did some electronic work, and removed the stearing wheel... aribag thingy, then when i put it all back, the srs light is on... whats the deal? Is this one of those "disconect the battery to let the ecu reset" kinda problems?
thats what i would do and if that don't fix it or if it comes back on alittle later then i would retrace what i did and make sure that all the conections are back in just right. bye chance did u have the key on when u were working on it? if so then it prolly just shot the code then.???? try it and let us know. peace and good luck
Tony D
DR
I did the same thing with my airbag when I pulled the harness off with the battery connected. Unfortunetly, disconnecting the ecu won't work, I believe the airbag is a different computer. The only way to reset the SRS computer is to have the dealer clear the code (my mechanic's scanner couldn't clear it thanks to Mits.). I had to call a couple of dealers before I found one that would clear it for $30. Most were trying to charge $80-$100 to clear the code.
  • For sale 1g B1H 4 bolt differential
    Hey guys, up for sale is my 4 bolt diff, price is $250 shipped.You must be registered to see...
    • 1cleangsx
  • For sale 4G63 JDM 4G63 Mitsubishi lettered valvecover
    JDM 4G63 valvecover. Mitsubishi lettered along with Diamond symbol. No broken holes or...
  • For sale 1990 Plymouth Laser RS Turbo (NE Oklahoma area)
    Car that I bought to drive for fun but need the money for college
    • InfiniteRevs
  • For sale 4G63 Holset HX Super 40
    Holset super 40 specs t3 .82ar with 3” vband exit, Billet compressor wheel 60mm inducer 86mm...
    • GST2012GSX
  • Wanted 1g 7 bolt oil pan N/A
    I need a 7 bolt oil pan for a 1992 eclipse with delivery to Europe
    • Xtalex
