ECMlink SD RICH AT WOT
bzjosh
Jul 21, 2016
Ketchikan, Alaska
I recently switched to SD. After getting a base tune loaded and a short cruise and a WOT in 2nd gear at the end. The AFR goes pig rich. I've done a compression, cylinder leakdown test and boost leak test. After banging my head against a wall i am at a loss. Ive attached a log
What size injectors are you using? Most everything looks fairly smooth, but I'm sure your global settings as for your injectors are too rich and you need to lean that out (make the injector size in ecmlink larger) and then dial in the deadtime/injbatteryadj once again. Assuming you have your rev limit set low while you're trying to dial things in. Your trims at cruise are a bit rich as well, but I'd worry about that after getting your global dialed in for wot.
Try putting in 2200 and then richen as needed. Bump your base fuel pressure to 50 psi.
