S-AFC Wiring Diagram for 95-99 Eclipse RS
mitsuRSupra
Mar 19, 2005
Anchorage, Alaska
I have a 99 eclipse RS with the stage 2 star turbo kit. i got the S-afc for free and im about 2 also get the Digital AVC-R Boost Controller for free only problem is.... cant find a wiring diagram for them. Does any one know where i can get them?
Mods:
Star Performance Stage 2 turbo
Rod Bearing Set
Main Bearing Set
JE Piston Rings
Oil Pan Gasket Set
Oil Pump
Eagle Specialty Forged Rods
JE Pistons
8.6:1 Turbo
Body:
12 piece body
supra tail conversion
GST spoiler
THANX....
I have never seen an install write up specifically for safc install on a nonturbo however I would imagine you would easily be able to find it over on www.2gnt.com. Another option you have is to locate the wiring diagram for the ecu on a 2g nt, then go to www.vfaq.com look under safc install for a turbo car and find out what wires need to be spliced and what needs to go where. Refer this info back to the wiring diagram for your n/t and figure otu which wires are which.
