Running Rich?
cucumber
2,475
7
May 17, 2002
I've had this recent problem with my car which leads me to believe I have a faulty 02 sensor causing my car to run rich, however, I'd like a second opinion.
On my mad-tyte-raver-blinky-show gauge, I'm reading full rich at WOT and at 10% throttle. I'm getting 15 MPG. I'm smoking black smoke. My plugs are black. I'd say I'm running rich, however, it has not thrown a CEL yet.
Does anyone have an idea?
I'd say I'm running rich, however, it has not thrown a CEL yet. Does anyone have an idea?
Just discussing this problem with another member but off list.
Have you checked the temp sensor on the thermostat housing???
I don't have a manual for you car but earlier models have a 2 wire sensor which will cause this problem. This will cause a more dramatic rich condition than the O2 sensor if it has failed completely. There are tests which specify immersion in water with a thermometer to determine resistance values. You might try Vfaq.com or a search here for those values. Do not confuse the smaller "temp sender" which controls the gauge and has a single wire. I've attached a jpg for a 1G if that helps.
My son's 1G went bad some months ago and we replaced it with a unit from Pep Boys for $38 which is about half what the factory wants. In theory these should last for 5 years to meet Federal smog laws so save a few bucks if it tests bad.
Cheers,
GTM
Cheers,
GTM
Interesting, thanks for the info. I'll have to check into that.
  • For sale 1g coil pack
    Used 1g (91-94) coil pack and bracket. One stud to mount the harness is broken, but still has...
  • For sale 4G63 OEM Balance Shaft Delete Kit
    OEM Balance Shaft Delete Kit $40 + shipping and PayPal fees* includes crank spacerYou must...
  • For sale Evo viii fuel pump
    Used Denso Evo 8 fuel pump. Similar flow to the Walbro 190. Plug n play for 2G's. Been...
  • For sale 2g 2G Hatch Weather Seal ( no rips or tears )
    2G Hatch Weather Seal $45 + shipping and PayPal fees* no rips or tearsYou must be...
  • For sale 2g 2GA Eclipse Fog Lights & Brackets
    2GA Eclipse Fog Lights & Brackets $70 + shipping and PayPal feesYou must be registered to see...
