fwdmaster
- 1,449
- 72
- Aug 15, 2007
San Diego,
California
I'm in the process of getting my spare 6 bolt block rebuilt with 2g pistons/stock 1g rods,what kind of rod bearings/main bearings do you guy's recommend getting?
Yes thread revival . So you don't think that the OEM will last with 500hp or more potentially? What's the reasoning since what was stated above is that all bearings do the same thing of allowing a thin film of oil to be traped between the bearing and crank.
So what you are saying is that if I plan to run some high numbers, I wouldn't want the tri metal as it's too soft?
Don't the harder bearings cause a lot of wear though?
I know that you know what you are talking about and trying to get through, but for me it' like . So I shouldn't use the OEM or would I be fine with them? I guess that's what I'm trying to understand. He said he's always used OEM for all his builds and they all put down some good numbers. He's currently rebuilding a new EVO and is going to use OEM in that as well.
