[RESOLVED] Motor mount not lining up?
JMiller
684
Jun 30, 2007
Irmo, South Carolina
OK my RS has been sitting with the passenger side motor mount in the trunk, so the engine has been hanging there for about 2 years. Today when i went to install the mount the hole was off about a 1/4 in.. So i was wondering do i need to loosen the other mounts and try to get the bolt in or can i put some washers(1 or 2) behind the mount bracket to get it moved over enough to put the bolt in?
Thanks in advance :dsm:
Ok i'll try that tomorrow, i need the engine to move to the lefta 1/4in., any idea which mount i should loosen first in order to do this quicker. Also is there anything i should know before i start loosening the other mounts.
Try placing a jack on the engin or transmission but not the oil pan. Depending on where you place the jack, the engine will move up and in a direction.
