Please Support STM Tuned
[RESOLVED] JB weld (how to get it off)
dsmulla
200
Jun 27, 2007
Scarborough, Ontario_Canada
Jb weld, I know its great and all the threads that have looked through have proven that. Is there anyway to get that stuff of?
The guy who dropped the motor in my car JB welded the oil drain line that comes from the turbo at the oil pan. I can see the two bolts but there is JB weld around them. I am guessing heating it up would help as I read somewhere online before that once you heat it up it becomes like chalk and a person can scrape it away.
I just need a little more insight into the matter? Would a heat gun be enough and is it safe to apply heat where the drain line meets the oil pan.
Thanks in advance
Osman
P.S No I can't take it back to the mechanic, its a long story.
Heating it up would help, but be careful not to melt anything under there, after that you should be able scrape it off. Also you could try to use some paint thinner if you dont want to heat it.
What a ####in dummy? Really, why would you bond something like that with jb weld. I dont know what to say. If you add heat to it, you will most likely melt the everything in sight. Paint thinner would be the best bet
JB Weld can be drilled and tapped, so I'm betting that its formed a 'gasket' and is sealed around the threads of the bolts. The bolts will probably also just thread back out of it.
Go to lowes or home depot and look in their paint department, look for a smallish blue metal can made by Klean-Strip, it'll say aircraft stripper or aircraft paint remover. It's thick stuff you can blot it on where the JB is and let it sit about 2 hours and then the JB Weld will be soft like silly putty.
Be Careful if you use it, the stuff is heavy duty and will burn your hands if not washed off fast enough.
UPDATE:
Ok guys, thanks for all your help and the paint thinner worked great. I put some in a spray bottle. sprayed and the JB Weld just started to chip away. AllwheelTSI, thanks for your input and I was considering that but that price of that stuff didn't favour me for this particular situation.
The two 10mm bolts have been stripped (atleast thats what I think) and I am willing bet thats why the mechanic JB welded the drain line. Both bolts seem to just spinning in one place and don't come out.
Any suggestions on what to do now? Drilling and tapping, is that the only option I have?
Cheers
Osman
you could drill and tap out to the next size bigger or you could use a helicoil and keep the same size.
im not exactly sure on the part your talking about since im new to dsm's, so it really depends how much meat you have on the part/area to redrill and tap.
You could always JB weld in some studs and use nuts, if theres room? Again im not too sure on the part just trying to throw out some idea's.
Goodluck!
Shy of pulling the pan it will be difficult to do it right. If your pan is like mine, their are only nuts welded on the back of the pan, so their is not alot of meat to try to drill oversize and put a heli-coil. They may be stripped or the welds on the nuts may have broke and they are spinning as a unit. If you cut the heads of the bolts off you will be able to tell if the nuts are broke free, but at that point pulling the pan will be necessary. Sorry, but i can't think of a better surefire way to fix it properly with out pulling the pan. Good luck and let us know how you make out
