OddNotion
- 135
- 2
- Jan 15, 2006
Fairfax,
Virginia
Well, you said you have the cams off? I guess if you can see where the tops of the valve stems are you can see that they are all in the same line (as i assume they should be, all valves should be closed with the cams removed, right?)
That way you know it's not piston/valve interference, which it seems was ruled out already. Just thinking out loud I guess.
