XC92
- 1,573
- 362
- Jul 22, 2020
Queens,
New_York
I need to replace the gear oil in my '92 Talon TSi AWD's rear diff as one of the final steps in a restoration project I've been working on since the summer. The car sat undriven for over 5 years, and before that probably didn't have the oil replaced for at least 5 years.
So I'm wondering if it makes sense to first replace the old oil with "sacrificial" gear oil, drive that for a while, and then put in fresh new oil, to clean things out.
I actually did this already with the trans and t-case when I dropped them a while back, replacing their old oil with Carquest Grease and Lube EP 90 GL-4 Gear Oil, which I intend to flush out and replace with Mitsubishi MTF 75W-85 for the trans and Redline 75W85 GL-4 gear oil for the t-case.
The "permanent" oil I'm going to put in the rear diff is Redline 75w-90 Synthetic Differential Gear Oil, which RTM recommends for my situation, a stock 1G DSM that it's going to be raced or driven too aggressive. I already have it, bought it a few months ago. It's GL-5, per FSM spec.
If using "sacrificial" oil this way is ok, can I also use the same EP 90 oil I put in the trans and t-case, even though it's GL-4 and the rear diff calls for GL-5, since we're only talking a few hundred miles, tops, and probably not even that much?
Or does it have to be GL-5, even for such a small number of miles? Or am I wasting my time doing this and should just put in the Redline GL-5 and be done with it?
Btw, either way, is a pump pretty much necessary to get new oil in the rear diff, or is there enough room to put a small funnel in the fill hole and slowly pour it in--or perhaps use a long flexible tube out the side or rear of the car (which should be fun when it's 35 degrees out)?
