Reducing valve adjustment
hellotbone
1,032
22
Apr 15, 2003
Where is the reducing vavle located? I had someone do my translab install but I see that you can also change the shift firmness with the recusing valve externally.
It is a 4mm screw on the valve body. You will be able to see it if you remove the filter.
-John
